![](https://thermalprocessing.com/wp-content/uploads/2022/09/TP-2022-09-Update-WPA-nadcap-e1663087805393.jpg)
Solar Atmospheres of Western PA (SAWPA) has received Nadcap accreditation for its new, fully integrated vacuum oil quench (VOQ) furnace.
Designed and built by Solar Manufacturing, this two-chamber VOQ furnace is completely sealed, meaning a significantly cleaner and safer oil quenching process. The entire VOQ system is much “greener” than traditional integral quench or open-pit quench furnaces.
With a maximum load weight of 2,000 pounds, the SAWPA VOQ furnace can successfully quench alloy steels and martensitic stainless steels to the most stringent of aerospace industry standards. Near-net shapes and finished products can be hardened by quenching in oil with minimal risk of surface contamination.
“I admit I was nervous the first time we ran low alloy steel parts for a military contract,” said SAWPA plant metallurgist Greg Scheuring. “I assumed there would be a minimal partially decarburized layer. But when the low alloy steel parts came out with no decarburization with zero intergranular oxidation (IGO), I knew the VOQ was going to open up a whole new market for SAWPA.”
MORE INFO www.solaratm.com
