Vastex infrared conveyor oven boosts temperatures
Capacity of BigRed™ 4D-54 infrared conveyor oven can be doubled or tripled as new or when needs increase by adding one or two additional heating chambers and extending the conveyor belt. (Courtesy: Vastex)
A new BigRed™ 4D-54 infrared conveyor tunnel oven from Vastex Industrial boosts temperatures to over 300°F (149°C) within the first several inches of conveyor travel, and maintains at-cure temperatures of up to 900°F (482°C), satisfying high-capacity curing, drying, and baking requirements.
It is equipped with a 54-inch (137 cm) wide conveyor belt, dual heating zones, and four height-adjustable infrared heaters capable of heating film, sheet, parts, and metal products uniformly from edge to edge, at high rates.
An air flow mapping system draws ‘make-up’ air into the chamber’s double-walled shell through filtered inlets along opposite exterior sides serving to cool the outer shell for safety, while preheating incoming air.
An exhaust fan located below the center of the conveyor belt draws the preheated air downward at rates up to 700 CFM (19.8 CMM) over and through the belt, removing heat, moisture, fumes, and contaminants from the chamber.
The six-inch (15.3 cm) diameter exhaust fan outlet can rotate 360 degrees for easy connection to ductwork, and the control box can be located on the right (standard) or left side of the chamber.
Exhaust filters located on both sides of the conveyor prevent dust, lint, or other contaminants from entering the blower or exhaust stack. Cleaning all filters before or after each shift can be accomplished in one minute according to the company, safeguarding the product, equipment, and shop environment.
Exhaust flow sensors with warning lights alert operators to a clogged exhaust line, clogged filter, or blower failure. Other safety features include a light tower to monitor oven status, and a ‘cool down mode’ for powering down.
With a total of 22,800 watts, it is wired for 240V as standard, and available in three-phase, 208, 380, and 480 voltages. The heaters carry a 15-year warranty, and feature closely spaced coils that provide high-density, medium-wavelength infrared heat for maximum IR efficiency without cold spots. Dual digital PID temperature controls maintain accuracy to ±1°F (±0.5°C).
A Teflon-coated fiberglass belt with alignment tracking system is standard. Optional stainless-steel mesh belts for high-heat applications are available.
Capacity (belt speed) can be doubled as new or retrofit by adding one additional heating chamber (total 45,600 watts), or tripled by adding two additional chambers (total 68,400 watts), and extending the conveyor belt.
All BigRed 4D-54 configurations are 71.4 inches (181.4 cm) wide x 51.6 inches (131.1 cm) high. Lengths are 105 inches (266.7 cm) for single chamber units, 142 inches (360.7 cm) for two-chamber units, and 178 inches (452.2 cm) for three-chamber units.
MORE INFO  www.vastex.com
