Vastex adds low-temperature cabinet oven
Dri-Vault 253610 low-temperature infrared oven for laboratory and small-batch applications up to 230°F/110°C filters particulates, exhausts fumes. (Courtesy: Vastex Industrial)
Dri-Vault™ 253610 low-temperature infrared cabinet oven for heating, drying, curing, and conditioning of bonded or coated parts has been introduced by Vastex Industrial.
Intended for small scale production and laboratory applications, it features a double walled enclosure with positive-pressure filtered air flow to prevent particulates from entering the chamber, and a four-inch (10 cm) exhaust duct to remove moisture and fumes. Latched doors with gaskets maintain total darkness during operation.
The 177 CFM (5 CMM) blower draws filtered air over an industrial stainless-steel finned heater at 1,250 watts (120V) or 1,550 watts (240V). Digital temperature controls allow variable settings from air-only up to 230°F/110°C in one-degree increments.
Non-corrosive, coated steel racks measuring 25 inches (63.5 cm) wide x 36 inches (91.4 cm) deep are vertically adjustable to fit items up to 24 inches (61 cm) tall.
Warrantied for three years, the unit measures 39.5 inches (100 cm) deep x 34.75 inches (88 cm) wide. Height is 32 inches (81 cm) with optional casters, 29 inches (74 cm) without.
Vastex Industrial manufactures two larger models of cabinet ovens and 11 models of high-temperature tunnel ovens for pilot testing up to high capacity production.
MORE INFO  www.vastexindustrial.com
