New Cotronics’ Thermeez™ 397PS is a highly efficient, high-temperature (up to 1,500°F), thermally insulating, woven ceramic tape backed with high-temperature, pressure-sensitive adhesive that’s easy to align and simple to apply. Eliminate the twisting, slipping, and unwrapping that normally occur with standard tapes. The adhesive backing simplifies tape placement and assures a neat and uniform installation for any thermal and electrical insulation application.
The tape is ideal for any industrial, maintenance, research, and production application including insulating wires, thermocouples, induction coils, sensors, tongs and glass-handling equipment, handling molten metals, hose or wire covers, flange gaskets, expansion joints, oven door seals, pipe wrapping, welding arc, and molten metal splash protection.
Thermeez 397PS is woven from durable, flexible, industrial-grade ceramic fibers that have excellent chemical stability and resistance to thermal shock, corrosive attack, mechanical vibration, and stress. Thermeez products are user-friendly and, unlike fiberglass, non-irritating to the skin. They are non-toxic and will not burn. They meet OSHA and U.S. Coast Guard requirements for non-combustible material. Cotronics’ products are formulated for ease-of-use and with safety in mind.
The tape is packaged in easy-to-use, job-sized rolls — one, two or three inches wide and 25 feet long. A sample kit containing 1/32”, 1/8” and 1/16” thick, two-inch wide by 5-foot-long rolls of Thermeez 397PS Sticky Tape is available.
MORE INFO www.contact.cotronics.com
