L&L provides MRO distributor bench-top furnace
L&L Special Furnace’s Model XLB124 high-uniformity bench model furnace on floor stand. (Courtesy: L&L Special Furnace)
L&L Special Furnace has delivered a highly uniform box furnace to a distributor of equipment to maintenance repair and overhaul (MRO) facilities located throughout the world.
The L&L Model XLB124 has working dimensions of 11” wide by 10” high by 22” deep. The furnace is capable of heat-treating a wide variety of tool steels — from D-2 to high-speed M-2 tool steel — along with low-temperature tempering. It is equipped with a sealed case for inert atmosphere capability, as well as a fully functional atmosphere control panel with pressure regulator, flowmeter, and manual shut-off valve.
Elements are very evenly spaced around the chamber. There is a manually operated, spring-assisted vertical door. Included is a NEMA 1 control cabinet with a Eurotherm program controller, high-limit backup system, thermocouples, fusing, and all interconnection wiring. Power control is accomplished with quiet two-zone, long-lasting solid-state contactors. The furnace hearth is a rugged cordierite plate with ceramic support.
The Model XLB124 is insulated with 2-1/2-inch lightweight firebrick and backed up with two inches of insulating board. The bottom is reinforced with a high-density calcium silicate that provides extra support for the load weight.
The L&L XLB series comes in several sizes, with custom configurations available upon request. There are also many options available for the XLB series, from atmosphere-sealed casing for use with inert atmosphere to an array of control and recorder varieties, along with recirculation fans and controlled cooling.
MORE INFO  www.llfurnace.com
