![](https://thermalprocessing.com/wp-content/uploads/2021/04/LL-Furnace-GS2026.jpg)
L&L Special Furnace Co., Inc. has shipped two model GS2026 heat-treating furnaces to a manufacturer of brick dies, textured stucco rollers, and extrusion equipment for the construction industry.
The furnaces are being used to meet an immediate need for increased heat-treating capacity. They provide a supporting role in the company’s die manufacturing process.
The Model GS2026 has internal working dimensions of 18” wide by 12” high by 24” deep. It has an operating voltage of 208, 220, 240 volts single phase, 60 or 50 hertz.
Included is a spring assist vertical lift door that allows for effortless loading and unloading even at high temperatures. The control is a Bartlett program control that can store multiple programs and includes overtemperature protection.
Standard units include a sheathed thermocouple, a slot in the door for access into the furnace, a bench-mounted, powder-coated CNC machined case, ceramic hearth plate with standoffs, a door limit switch that turns the power to the elements off if the door is opened, an on/off toggle switch with control fusing, and a power plug. An optional angle iron stand and vent kit are available.
The furnace is shipped by common carrier on a skidded carton with foam-in-place packaging. L&L has some units in stock available for same-day shipment. Units with control upgrade or fan option usually ship within one to three weeks.
L&L touts the GS2026 as a great choice for general-purpose heat treating as well as high tech industrial applications.
MORE INFO www.llfurnace.com
