Blue M ships stacked mechanical convection oven
Blue M®, has shipped a stacked mechanical convection oven to be used for non-hazardous curing applications between 300°C and 400°C. (Courtesy: Blue M)
Blue M®, a global industrial and laboratory ovens manufacturer, has announced the shipment of a stacked mechanical convection oven to be used for non-hazardous curing applications between 300°C and 400°C.
This oven features custom shelving designed to ensure safe and convenient loading and unloading for operators. Each chamber features a pair of welded C-channel shelf slides with a non-tip design, allowing shelves to extend 3/4 of the way out without risk of tipping. Teflon strips on the slides provide smooth, easy movement, even under heavy loads. Positioned at the lowest point of each chamber, the shelves support up to 100 pounds, accommodating various product weights, configurations, and load requirements.
Each oven chamber has interior chamber dimensions of 25” wide x 20” deep x 20” high, constructed from all-welded heavy gauge, reinforced stainless steel for maximum heat and corrosion resistance. The oven’s temperature range is between 27°F above ambient and 475°F. The temperature is controlled by a Watlow EZ Zone PM microprocessor-based controller with an advanced PID control algorithm and TRU-TUNE™+ adaptive control. The heating and air delivery system uses horizontal airflow to ensure even heat distribution throughout the chambers. For added safety, an airflow switch is included to disable the heating elements in the event of a blower system failure.
“At Blue M, we are committed to delivering solutions that exceed customer expectations,” said Jonathan Young, Blue M product manager. “The shelving system in this stacked oven was engineered with the customer’s operational needs in mind. Strategically positioned to maximize space, the shelves are designed to safely handle heavy loads, while the slide mechanism ensures smooth and easy movement for the operator.”
Unique features of this Blue M stacked oven include:
  • Non-tip shelving system rated for up to 100 pounds.
  • Integrated stacked system with right hinged doors.
  • Horizontal airflow to maximize heating rates.
  • Watlow EZ Zone PM microprocessor controller.
  • Over temperature controller.
  • Direct drive ball bearing motor with a balanced stainless steel multi-bladed blower wheel.
  • Automatic airflow switch.
MORE INFO  www.bluem.com
