Gasbarre commissions furnace for U.S. heat treater
Gasbarre Thermal Processing Systems recently commissioned a precision gas nitriding and ferritic nitrocarburizing furnace for a commercial heat-treating company. (Courtesy: Gasbarre)
Gasbarre Thermal Processing Systems recently commissioned a precision gas nitriding and ferritic nitrocarburizing furnace for a prominent commercial heat-treating company in the Midwestern United States. The furnace uses Super Systems, Inc. controls for automatic KN and KC control to AMS 2759/10 and 2759/12 specifications. The furnace is designed to meet AMS 2750/E as a Class 2 furnace, which allows it to be used to perform nitrogen tempering and stress relieving processes. For cycle time improvements and consistent process control the furnace is equipped with a vacuum pump for purging processes, pre- and post-oxidation capabilities, and accelerated air and atmosphere cooling systems. It is capable of processing workloads that are 48” wide by 72” long by 40” high and weigh up to 7,000 pounds. Gasbarre Thermal Processing Systems says this complete system is engineered, manufactured, and serviced out of its United States locations, solidifying its position as a leader in equipment for the nitriding and FNC process.
With locations in Plymouth, Michigan; Cranston, Rhode Island; and St. Marys, Pennsylvania, Gasbarre Thermal Processing Systems has been designing, manufacturing, and servicing a full line of industrial thermal processing equipment for nearly 50 years. Gasbarre’s product offering includes both batch and continuous heat-processing equipment and specializes in temper, tip up, mesh belt, box, car bottom, pit, and vacuum furnaces as well as a full line of replacement parts and auxiliary equipment that consists of atmosphere generators, quench tanks, and charge cars. Gasbarre’s equipment is designed for the customer’s process by experienced engineers and metallurgists.
MORE INFO  www.gasbarre.com
