![](https://thermalprocessing.com/wp-content/uploads/2020/08/gasbarre.png)
Gasbarre Thermal Processing Systems shipped a continuous vacuum furnace with 10 BAR pressure quench capabilities to a major aerospace manufacturer in North America. The four-position, four-zone furnace is rated to 2,400°F. The independent load and quench modules allow the heat module to hold temperature and vacuum, creating an extremely pure environment. Extended heating element coverage allows for excellent temperature uniformity. As only the workload is cooled in the isolated cooling chamber, it makes for an efficient system. Quick transference from the heat module to the cool module and fast quench capabilities make this an ideal vacuum furnace to process medium- to high-volume parts. Gasbarre was chosen as the equipment supplier based on proven performance from past projects with this manufacturer, as well as extremely low down-time metrics with their existing Gasbarre vacuum furnace equipment.
With locations in Plymouth, Michigan; Cranston, Rhode Island; and St. Marys, Pennsyslvania; Gasbarre Thermal Processing Systems has been designing, manufacturing, and servicing a full line of industrial thermal processing equipment for nearly 50 years. Gasbarre’s product offering includes batch and continuous thermal processing equipment for both atmosphere and vacuum applications as well as a full line of alloy fabrications, replacement parts, and auxiliary equipment, which consists of atmosphere generators, quench tanks, washers, and charge cars. Gasbarre’s equipment is designedby experienced engineers and metallurgists.
MORE INFO www.gasbarre.com
